1994-2003 Standard 7.3 Powerstroke DT444 Injector Rebuild Kit
$175.00 175.00
This is a standard injector rebuild kit for all 1994-2003 7.3L Powerstroke Diesels. This kit contains everything needed to rebuild all 8 injectors. We source all of our injector parts from Italy to give you a combination of quality and price! Don't waste your time with cheap o-rings from China. This rebuild kit is used all around the world to rebuild HEUI injectors. We have put together all of the normal wear items typically found in these injectors to save you time and money. We can help you replace other components if you find damage after tear down. If you have someone else rebuild your injectors there is no guarantee that all of these components will be replaced as they can cut corners to keep their cost down. Rebuilding your injectors is not difficult if you have mechanical skills. Check our video page for Youtube videos that can help you if you have not done this before. You will be completely satisfied with this kit. Combine this rebuild kit with our rebuild tool for a seamless rebuild.
(8) External O-ring Kits (Italy)
(8) Internal O-ring Kits (Italy)
(8) Nozzle Springs (Italy)
(8) Poppet Springs (Italy)
(8) Armature Plate Screws (Italy)
(16) Check Balls (Italy)
Injector Diagram
*OPTION* Injector Rebuild Tool Kit also available separately link
