B.A.S.S. Injectors - 7.3 Powerstroke
$2,800.00
$2,900.00
2,800.00
New to market and built to order; the B.A.S.S injector is the only hybrid split shot injector to ever be developed for the 7.3 Powerstroke. The B.A.S.S. injector will deliver up to 300cc of fuel (depending on nozzle size) while maintaining the factory super duty idle and emissions characteristics. Now you don't have to compromise on installing the loud modified single shot injectors when wanting more performance from your injectors.
The split shot injection delivers a small quantity of fuel 8-10 degrees before the main injection. The use of this pilot injection shortens the ignition delay period which reduces combustion noise. Through shortening the ignition delay period, injection timing can be retarded which can reduce the formation of NOx emissions.
Do you want to replace your smoking injectors? Are your leaking injectors causing a long or no-start condition?
Our remanufactured 7.3 Powerstroke injectors exceed OEM specifications. We guarantee that with an industry leading three (3) year unlimited mile warranty against defects in material and workmanship. We recommend adding the optional accidental protection if you would like your injectors to be covered from damage by the user, vehicle, fuel etc.
Why are we so confident in our remanufactured injectors?
The upper and lower poppet valve seat of each injector core is flow tested to ensure the leak rate is equal to or less than a new injector. Injector cores that exceed our leak rate standard are disqualified from our remanufacturing process as they will not operate properly in a vehicle.
Injectors are fully disassembled and ultrasonically cleaned
Injector bodies and components are precision ground and matched to correct wear and flow restrictions
All sealing faces are lapped to prevent internal leaking
Solenoids are inspected for proper coil inductance, resistance and visual damage
Injectors are assembled with new orings, springs, plunger/barrel assemblies, and nozzles
Nozzle opening pressure and proper fuel plate function is tested
Internal injector components are measured and calibrated to exceed OEM specifications.
Injectors are conditioned and endurance tested on the flow bench prior to sample collection
Injectors are built as a matched set rather than large production batches
