High Performance - 7.3 Powerstroke Injector Set
$1,450.00
1,450.00
Do you want to replace your smoking injectors? Are your leaking injectors causing a long or no-start condition?
Our remanufactured 7.3 Powerstroke injectors exceed OEM specifications. We guarantee that with an industry leading three (3) year unlimited mile warranty against defects in material and workmanship. We recommend adding the optional accidental protection if you would like your injectors to be covered from damage by the user, vehicle, fuel etc.
Why are we so confident in our remanufactured injectors?
Each core injector is tested for upper and lower poppet valve seat sealing performance
Injectors are fully disassembled and ultrasonically cleaned
Injector bodies and components are precision ground and matched to correct wear and flow restrictions
All sealing faces are lapped to prevent internal leaking
Solenoids are inspected for proper coil inductance, resistance and visual damage
Injectors are assembled with new orings, springs, plunger/barrel assemblies, and nozzles
Nozzle opening pressure and proper fuel plate function is tested
Internal injector components are measured and calibrated to exceed OEM specifications.
Injectors are conditioned and endurance tested on the flow bench prior to sample collection
Injectors are built as a matched set rather than large production batches
