6.7 Powerstroke Injectors
Our BDP modified injectors are built to order. Send us a message for current build time or purchase and we will add you to the production queue.
Our performance built injectors are rated for actual fuel flow over a stock injector on an OEM injector test plan. We simply do not use the honed nozzle size for marketing our injectors. Building our injectors for actual fuel flow gives our customers the best value on the market.
Do you want to replace your smoking injectors? Are your leaking injectors causing dangerously low or no-start rail pressure?
These new OEM stock or BDP modified injectors come with an industry leading two (2) year unlimited mile warranty. Injector damage caused by the customer or vehicle is not covered under warranty. It's a good idea to check your fuel pressure before installing new injectors.
Since we build our injectors as a balanced set to ±1% at the rated flow, we hold tighter tolerances than the mass produced options on the market. We spend the extra time to make them right. Most shops are satisfied with 4% or higher. This is where having a machine shop is a great benefit to our customers. We modify injector components to achieve the exact specs we need.
The calibrated injectors are verified on our injector flow bench using a custom BDP test plan for the injector. The injectors must pass the seal performance and delivery under:
- Idle
- Pre-injection
- Mid-range
- Max fuel
Each injector set ships with the flow bench test results and all orings/copper crush washers for injector installation. The injectors will arrive ready for you to install in your vehicle.
Core injectors should be returned within thirty (30) days.
