KC Stage 2 Turbo - 6.7 POWERSTROKE (2015-2019)
Product Code: 300851
$2,190.00 2,190.00
** Core Credit Acknowledgement** Core's are required to be 2015-2019 turbo's in good working condition to receive the full $800 credit, we reserve the right to credit back less based on our inspection upon arrival (we do not accept Cab and Chasis Turbos as Cores)
  • Upgraded Billet 64mm Compressor
  • Upgraded 10 Blade Turbine Wheel
  • Improved Boost Controll
  • Cooler EGT's
  • Quick Spool Up
  • 100% Drop in Ready
You can choose a Re-manufactured turbo or a brand new stock 2017-2018 turbocharger for the 6.7 Powerstroke. If you are in need of a replacement turbo or simply want to upgrade your 2011-2016 to the newer style, this is the one for you.
This is a 2015+ direct turbo drop in for your 6.7 Powerstroke. We modified the the compressor housing to fit our upgraded 64mm compressor wheel. It features a KC turbos 10 blade compressor wheel, giving it that unique 2003 turbo whistle. The 2015 and 2016 year trucks will need additional coolant hose, coolant line, pedestal, a gasket and filter. in order to install it. It is about $100.00 from Ford.
Ford part numbers:
  • HC3Z-6C683-A
  • FC3Z-9U469-B
  • HC3Z-6587-A
  • HC3Z-6N639-A
  • BC3Z-6587-A
**If you have a 2011-2014 year 6.7 you will need a retrofit kit in order to install this turbo**
