Stock - DT466/530 Remanufactured Injectors 1994-2003
$1,250.00 1,250.00
Most of our injectors are built to order. Send us a message for current build time or purchase and we will finish a set for you right away.
Do you want to replace your smoking injectors? Are your leaking injectors causing a long or no-start condition?
Our remanufactured DT466/530 injectors meet or exceed OEM specifications. We guarantee that, with an industry leading two (2) year unlimited mile warranty.
Why are we so confident in our remanufactured injectors?
Each injector we receive is fully disassembled and cleaned in our heated ultrasonic tank with a proprietary cleaning solution.
After cleaning, the injectors receive new orings, springs, plunger/barrel assemblies and nozzles. Next, each injector is recalibrated to meet or exceed OEM specifications.
Our injectors are balanced for nozzle opening pressure and max discharge rate to within 2% or better at the rated flow. We spend the extra time to make them right. Most shops are satisfied with 4%. This is where having a machine shop is a great benefit to our customers.
The calibrated injectors are verified on our injector flow bench. We test every injector for:
  • Leak Test
  • Idle Discharge
  • Max Discharge
Once the injectors are verified to meet our standard, they are resealed with new Alliant Power USA external orings. They will arrive ready to be installed by the customer.
Each injector ships with the flow bench test results for that injector.
Core injectors must be returned within thirty (30) days.
