2003-2010 Deluxe 6.0 Powerstroke Injector Rebuild Kit
$230.00 230.00
A rebuild kit can delay, but is not a substitute for fully remanufactured injectors. If you have high mileage injectors or a catastrophic injector failure we recommend our remanufactured injectors.
This is a complete injector rebuild kit for all 2003-2010 6.0 Powerstroke Diesels. This Deluxe kit contains everything needed to rebuild all 8 injectors. We source all of our injector parts from USA and Italy to give you a combination of quality and price. The external o-rings in this deluxe kit are manufactured by Alliant Power the best in the market. Don't waste your time with cheap o-rings from China. This rebuild kit is used all around the world to rebuild 2003-2010 6.0 Powerstroke injectors. We have put together all of the normal wear items typically found in these injectors to save you time and money. We can help you replace other components if you find damage after tear down. If you have someone else rebuild your injectors there is no guarantee that all of these components will be replaced as they can cut corners to keep their cost down. Check our video page for Youtube videos that can help you if you have not done this before
This deluxe rebuild kit contains the following parts:
(8) Alliant Power External O-ring Kits Including Top Oil Seal And Ring
(8) Internal O-ring Kits
(8) Nozzle Springs
(8) Plunger Springs
(8) Check Balls
Injector Diagram
We would be happy to help you with any other injector parts you may need.
