2004-2006 6.6 Duramax LLY Injector Rebuild Kit With Tools
Brand: Stocking
$299.00 299.00
Thank you for choosing Bitterroot Diesel Performance and Manufacturing for your diesel repair needs. We operate a full injector remanufacturing shop. We have been supplying DIY injector rebuild kits for many years all around the world. Our customers have saved thousands of dollars repairing their own injectors. We are available for technical support and sales.
This is an injector rebuild kit for all 2004-2006 6.6 Duramax LLY diesel injectors. The 8th digit of your VIN will be a (2). This kit contains seals, springs and check balls to replace your worn out and leaking seals. All of our injector parts are manufactured in Italy giving you the best combination of quality and price! We have sold this rebuild kit all around the world. If you find other issues after tear down, then we can provide you with additional options to get your injectors back into shape. Videos are available on YouTube to assist you during rebuild of your injectors.
(1) Billet High Pressure Seal Installer
(1) Two Piece Billet Solenoid Socket
(1) Control Valve Retaining Nut Bit
(8) External O-ring Kit
(8) Internal O-ring Kits
Injector Diagram
Phone Support
*Please note*
Your injectors may currently be out of Bosch specification. Rebuilding of your injectors may require them to be re-calibrated to bring them back into Bosch specification. Unfortunately for the DIY, this is only possible with special calibration tools and shims which must be verified on an injector flow bench.
The number one reason we see an injector needing to be serviced is a worn out high pressure seal. This allows high fuel return rates. The more serious problem for high fuel return rates is caused by a worn out/damaged control valve. Replacement of the control valve will require the injector to be re-calibrated and tested on an injector flow bench. We also find it common that the nozzles have fallen out of Bosch specification causing decreased fuel delivery.
We remanufacture common rail injectors in house with new Bosch control valves and nozzles. Each injector is then flow tested and the flow test data is sent with each injector. Our remanufatured injectors come with a two year, unlimited mileage warranty. We have the most competitive prices in the industry backed by the best customer service.
We are your connection for more than 15,000 products for your Powerstroke, Cummins and Duramax vehicle.
At Bitterroot Diesel Performance, our goal is complete customer satisfaction. We are a small company who focuses on communicating quickly with every customer. Here, we choose quality over quantity. Every day we work hard to give our customers every option that is available. We started as a supplier of DIY injector rebuild parts and tools. Today we have grown to supplying thousands of parts for your diesel pickup, in addition to in house remanufactuing of common rail injectors. We use the latest CNC technology to manufacture our injector tools and diesel accessories with domestic material. When we're not shipping orders, talking with customers, or remanufacturing injectors, you'll find us playing with CAD and R&D for our next project. Please contact us with any questions. We're a veteran owned company, and we thank you for your business.
Follow us on Instagram and Facebook.
