7.3 Powerstroke DIY HEUI Flow Bench Controller
Brand: Stocking
$1,000.00 1,000.00
This is the only 7.3 Powerstroke HEUI flow bench controller on the market. Use this controller to make your own injector flow bench for testing 7.3 Powerstroke or DT444 injectors. Building your own flow bench will save you thousands over purchasing a commercial flow bench. This is a small stand alone controller that is simple to use. This controller simulates the PCM signals to the IDM.
What's included:
  • Flow bench controller
  • USB update cable
What you need:
  • Powerstroke IDM
  • UVCH
  • Single Powerstroke head
  • Fuel pump
  • 3,000+ PSI hydraulic pump
  • Heated oil tank
  • 12 volt power supply
