Leakproof Nipple Cup/Ball Tube MASTER KIT : 1-Tool, 8-Cups, 8-Seals
Brand: HHC Diesel
Product Code: F60L-NIPPLEKIT
$349.99 349.99
The Final Step in Leakproofing Your 6.0L Diesel Engine!!
If You're Going to Install Head Gaskets and ARP Studs, You Might As Well Leakproof Your Oil Rails Too!
After 2 Years of Research & Development We Are Proud to Offer The First & Only leakproof Nipple Cup/Ball Tube Design! Our Patent Pending Design is Made of Hardened Tool Steel & Features a Deflection Groove to Make Sure a Leak At The Nipple Cup Seal Will NOT Follow the Body of the Nipple Cup To Your Top Injector Seal and Cause a No Start. Don't Get Stranded Re-Using Your OEM Nipple Cups or Some Cheap Aftermarket Nipple Cups!
The shape and size of every single part of our nipple cups has been designed and tested to insure the best possible seal in both a brand new high pressure oil rail and an old worn out rail. Even in the worst conditions, our nipple cups out-perform the competition and the original OEM design. The other aftermarket options are not only made of soft steel, which will wear out quickly, but they are also smaller than the OEM cups. In an older oil rail, a smaller nipple cup will not seal as well and you will end up with leaks sooner than later
1- Nipple Cup Impact Socket, 8- Leakproof Nipple Cups, 8- Ultra Heavy Duty Viton O-Rings
Leakproof Nipple Cup Features:
  • Patent Pending Leakproof Design
  • Made of Hardened Tool Grade Steel
  • Deflection Groove Diverts Any Oil That Leaks Past the Nipple Cup Seal Harmlessly Away from the Top Injector Seal
  • Works With All 6.0L Oil Rails - 2003-2007
  • Limited Lifetime Warranty - Guaranteed to be a one time purchase that will last as long as your truck
  • Will Never Leave You Stranded With a No Start Condition Due to Failed Top Injector Seals
  • Optimized Shape and Size to Seal Better Than OEM or Other Aftermarket Cups in New and Old Rails
  • Buy It Once and Be Done. Never Worry About it Again!
Tool Features:
  • 1/2" Square Socket Drive - Fits Right on Your Impact Wrench
  • Made of Hardened 4140 Impact Grade Steel
  • Black Oxide Coating - Permanent Corrosion Resistance
  • Limited Lifetime Warranty - If you Break it Send it Back & We'll Replace it No Questions Asked
  • Impact Friendly - Unlike the Other Tools on the Market, You Can Use and Impact on Our Tool
  • Signature HHC Diesel Design Optimizes Torque Points on The Lock Ring
  • Can be Used to Center the Nipples Before Re-Installing the Oil Rail
  • Unlike the Cheap Tools on ebay Ours Won't Break Or Round Off in the Middle of your Job and Leave You Stuck With Your Pants Down
O-Ring Features:
  • Premium Heavy Duty Viton Blend - Ours Are The Best
  • Works With All 6.0L Oil Rails 2003-2007
  • Uniform Textured Finish - No Mold lines to Compromise Your Seal
Want Additional Information on The Issue These Fix?
If you are having No-Start issues on your Ford 6.0L especially if they are Hot No-Starts, you may have leaking Nipple Cup O-Rings. I won't waste your time explaining the problem and the symptoms here.Read The Comprehensive Forum Thread Over on FTE:
http://www.ford-trucks.com/forums/1238249-fuel-injector-top-o-rings-seals-the-whole-story.html
You Must Replace Your Top Injector Seals at The Same Time You Replace Your Nipple Cup O-Rings!
