- Contact for availability-
Alliant Power 7.3 Powerstroke Injectors – New & Remanufactured
Bring your 7.3L Powerstroke back to life with Alliant Power fuel injectors, available in new or remanufactured options. Designed as direct-fit replacements for 1994–2003 Ford 7.3 Powerstroke diesel engines, these injectors deliver dependable fuel delivery and smooth, consistent engine performance.
Alliant Power injectors are built to OEM specifications and are ideal for replacing worn or failing factory injectors. Whether you’re maintaining a daily driver, work truck, or tow rig, these injectors provide the reliability and fitment Powerstroke owners expect.
Key Features & Benefits
Direct-Fit Replacement for 1994–2003 Ford 7.3L Powerstroke engines
New or Remanufactured Options to fit different budgets and build goals
OEM-Spec Fuel Delivery for smooth idle and balanced engine operation
Improved Drivability including better throttle response and consistent power
Compatible With Stock Tuning – no modifications required
Ideal For:
Stock injector replacement
High-mileage engine refreshes
Daily drivers and work trucks
Towing and light-duty performance use
Available Injector Codes:
AA, AB, AC, AD, and AE (long-lead injector for #8 cylinder applications)
Why Choose Alliant Power?
Alliant Power is a trusted name in diesel fuel systems, offering injector solutions that match factory fitment and performance. With both new and remanufactured options available, you can choose the right balance of value and longevity for your 7.3 Powerstroke.
AA Injectors
Designed for 1994–1997 non-California trucks, these injectors feature a proven single-shot design with a 90cc fuel delivery rate, ideal for stock replacements and restorations.
AB Injectors
Used in 1997 California-emissions trucks and all early-1999 models, AB injectors utilize a split-shot design and flow 130cc of fuel for smoother operation and improved drivability.
AC Injectors
Found exclusively in high-torque T444E applications and never used in Powerstroke engines. These injectors share internal components with AB injectors but use a single-shot plunger and barrel, delivering increased fuel flow of 160cc.
AD Injectors
The standard injector for late-1999 through 2003 Powerstroke and T444E engines. These split-shot injectors offer a well-balanced combination of performance, reliability, and everyday drivability.
AE Injector
A long-lead version of the AD injector designed specifically for the #8 cylinder to address cold-start “cackle” and improve idle quality.
AA Injectors
AB Injectors
AC Injectors
Found exclusively in high-torque T444E applications and never used in Power Stroke engines. These injectors share internal components with AB injectors but use a single-shot plunger and barrel, delivering increased fuel flow of 160cc.
AD Injectors
The standard injector for late-1999 through 2003 Power Stroke and T444E engines. These split-shot injectors offer a well-balanced combination of performance, reliability, and everyday drivability.
AE Injector
