Fuel Injector Sleeves 1994-2003
Brand: Alliant Power
Product Code: AP63411
$152.60 152.60
A complete set of 8 Alliant Power high quality fuel injector sleeves that fit all 1994-2003 7.3 Powerstrokes. If you are pulling injectors take the time to change the cups while you are there. Even if your cups are in good shape your sealing compound could be close to failing.
You'll need an injector cup puller which you can rent from us and Loctite 620 or Permatex Sleeve Retainer. We also recommend our injector brush to clean the old sealing compound from the heads.
