Billet Aluminum ZF5/ZF6 shift boot bezel Ford OBS/Superduty
Product Code: BDP-ZF6BOOTAMACH
$200.00 200.00
Upgrade Your Interior with American-Made Strength
If you're tired of dealing with a cheap, light-duty, and broken plastic shift boot bezel, it’s time for a permanent solution. Our heavy-duty billet aluminum replacement is designed to be the last bezel you’ll ever buy for your truck.
Precision-machined in Montana, this bezel is a rugged, drop-in replacement that adds a high-end feel to your manual Ford's interior.
Product Features:
  • USA 6061 Billet Aluminum: Solid design that will not crack or warp like the OEM plastic bezels.
  • Direct Fit: A true drop-in replacement for a seamless installation.
  • Complete Hardware Kit: Comes with stainless steel screws and new push nuts.
  • Made in Montana: Proudly manufactured in the USA.
  • Vehicle Compatibility: Fits all Powerstrokes equipped with a ZF5 or ZF6 transmission (OBS and Super Duty).
Available Finish Options:
  • Tumbled: A clean, industrial raw aluminum finish.
  • Tumbled and Polished: A high-luster, reflective finish for a custom look.
  • Black - Type III Hardcoat Anodized: Our most durable option. Unlike standard decorative coating, Type III Hardcoat creates a ceramic-like surface that is extremely resistant to scratches and wear. Perfect for work trucks and heavy-use environments.
