Garrett Non-EBPV Turbo Pedestal - 7.3 POWERSTROKE (99.5-03)
- Pedestal includes 4 O-Rings.
- Also works with stock turbos.
Get rid of your EBPV (Exhaust Back Pressure Valve) With this Garrett Non-EBPV pedestal for the 7.3 Powerstroke (99.5-03). This is a great addition when using the Garrett high flow outlet or a “gutted” stock outlet. This direct bolt-in replacement for the factory pedestal will eliminate leaks from the EBV actuator assembly and works with the factory turbo, Garrett GTP38r ball bearing turbo, and Turbonetics ball bearing “drop in” turbos.
