2003-2010 6.0 Powerstroke Injector Spool Valve Set
Use these made in Montana spool valves to replace your worn and damaged valves. These spool valves fit all 2003-2010 6.0 Powerstroke diesel injectors. New spool valves will not fix your injectors if your spool valve housing is damaged or has been previously remanufactured with a larger valve..
This kit contains 8 new spool valves ready to be installed.
