VegiStroke V4 Full Kit
Product Code: BFTVSV4
$5,000.00 5,000.00
Introducing the V4 Complete Vegistroke Flex Fuel System!
This heated standalone fuel system gives you the ability to run B100, Filtered Straight Vegetable oil, Filtered Waste Vegetable oil, Kerosene, Regular diesel, and even filtered waste motor oil in an offroad environment. Most advanced alternative fuel system for the PowerStroke anywhere...
SSB allows you to see Temperature status, Pump status, Pressure status, as well as your Engine Run and Purge Solenoid data.  In addition, visual cues are given for failed fuses and micro-relays.
SSB keeps a running (and resettable) time for your filter, your pump, number of pressure switch cycles, and your purge solenoids.
This kit includes:
V4 manifold complete with the Scorpion 2 gear pump, prefilter screen, fuel pressure regulator, purge solenoid, temperature switch, pressure switch and a 10 micron fuel filter
Coolant and fuel lines
Engine check valves
SSB Core brain
Wiring harness
Isspro Fuel pressure gauge
OLED display (with case)
OLED USB Cable (to plug in to USB)
** NOTE: This kit does NOT include a tank.
    *** Please note this item cannot be shipped to a PO Box ***
    BFT Vegistroke Install Manual
    BFT SSB Install - Usage Manual
