VegiHD V5 Complete Class 8 Heavy-Duty Alternative Fuel System
Product Code: BFTVEGIHD
$10,000.00 10,000.00
VegiHD V5 Complete Heavy-Duty Alternative Fuel System For Class 8 Vehicles
The Ultimate Commercial-Grade Dual-Fuel System for Class 8 Trucks & Vocational Equipment
Transform your heavy-duty fleet’s operating costs by tapping into local waste vegetable oil (WVO) supplies. Designed specifically for vocational, regional, and municipal Class 8 drivers; such as dump trucks, roll-offs, heavy haulers, and local delivery rigs who return to a home base daily with access to large-quantity local oil collection.
The VegiHD V5 gives you the ability to run B100, Filtered Straight Vegetable Oil (SVO), Filtered Waste Vegetable Oil (WVO), Kerosene and Regular Diesel. It is the most advanced commercial-grade alternative fuel system ever built for heavy-duty platforms.
SSB — Solid State Brain: Digital Control & System Safety
NO MORE GUESSWORK IN THE CAB.
The SSB digital controller replaces legacy analog switches with a digital microcontroller running custom control software. Paired with a compact in-cab OLED display, it provides straightforward monitoring and engine protection:
  • Real-Time Digital Display: See system temperature, pump state, engine run mode, and purge solenoid status at a glance.
  • Component Diagnostics: On-screen display of failed fuses or relay faults.
  • System Safeguards: Programmable purge and run timers, plus automated safety shutdowns for low fuel pressure or low oil temperature to protect your engine.
  • Hour Tracking for Tax & Maintenance: Integrated resettable hour meters log time spent running on alternative fuel making state motor fuel tax / IFTA reporting and filter maintenance tracking simple and accurate.
Built for Class 8 Commercial Duty (160°F–200°F WVO)
Engineered specifically for high-displacement Class 8 engines equipped with mechanical injection pumps and high-pressure unit injectors (HEUI, MEUI, EUI, HPI) that thrive on hot, low-viscosity fuel:
  • Billet Aluminum Manifold: Precision CNC-machined aluminum block absorbs and retains massive coolant heat, maintaining oil temperature above 160 degres even during high-load pulls or prolonged idling in cold climates.
  • Ultra-Fine Injector Protection: Integrated filter base directly accepts 4-micron absolute filters like the Donaldson Blue DBF5817 to protect expensive unit injectors and mechanical transfer pumps from abrasive wear.
Universal Class 8 Engine Compatibility
Open to all Class 8 platforms utilizing mechanical or high-pressure fuel pumps designed to handle hot WVO flow:
  • Caterpillar: C10, C12, C15, C16, 3126, 3406E
  • Detroit Diesel: Series 60 (11.1L, 12.7L, 14L)
  • Cummins: N14, ISM, ISX
  • Mack: E7, E-Tech, ASET
  • International / Navistar: DT466, DT530, HT570
  • Military Surplus: MTVR (MK23/MK25), LMTV, FMTV, HEMTT
  • And Others!
Road Tax & Compliance Ready
Operating alternative fuels on public highways requires tracking fuel usage for state motor fuel road taxes and International Fuel Tax Agreement (IFTA) reporting:
  • The SSB's integrated run-time meter logs the exact operational hours in alternative fuel mode.
  • Gives commercial operators and fleet managers an easy, reliable baseline to calculate gallon usage for tax logging alongside physical fill-up records.
What’s Included in the VegiHD V5 Kit:
  • VegiHD V5 Heated Billet Manifold Assembly (Complete with high-output pump, internal pre-filter screen, fuel pressure regulator, purge solenoid, temperature switch and pressure switch.
  • High-Efficiency 4-Micron Fuel Filter
  • Coolant & Fuel Line Plumbing Package
  • Application Specific Check Valves
  • SSB Solid State Brain Digital Controller
  • In-Cab OLED Display (with protective enclosure & USB cable)
  • Wiring Harness
  • ISSPRO Fuel Pressure Gauge
Ordering & Availability:
BUILT TO ORDER: Each VegiHD V5 system is precision CNC-machined and assembled to order.
HOW TO PURCHASE: This item is kept marked as Out of Stock. Please Contact Us directly to discuss your engine configuration, mounting setup, and place a custom order.
NOTE: This kit does NOT include a fuel tank. Tank and heated pickup should be sourced locally.
Please note: This item cannot be shipped to a PO Box.
