BFT Scorpion 2 Pump and Motor
The updated Scorpion motor specs trump the first-generation pump motor with the following improvements:
- ~30% increase in RPM, increasing from 70GPH to 97GPH at 70psi
- Maximum 12a draw
- Improved case sealing, resulting in better weather/element protection.
- Seals and armature winding insulation rated to 390*
- All parts interchangeable with previous generation Scorpion line.
- This pump is rebuild-able/user-serviceable.
- This contains everything you need to directly bolt on to your V3/V4 manifold.
- This pump was designed to withstand the punishment of the temperatures and fuel pressures needed to feed your V3/V4 system.
- Comes with adapter plate, mounting screws, and O-ring
*This pump not designed for use with V1 or V2 Vegistroke kits*
