Hydra Chip – Performance Chip for 7.3L Power Stroke Vehicles
HYDRA CHIP™
DEPENDABLE POWER AT YOUR COMMAND
Hydra Chip™: The only 7.3L PCM chip that gives you full, absolute control
It’s not just a chip you’re purchasing… it’s a key to unlocking world-class performance tuning. Every chip comes with FREE access to our entire library of calibrations for stock trucks. You choose what power levels you load onto your chip. Our easy-to-use HydraFlash software gives you full control.
The Hydra Chip works on all 7.3L Power Stroke vehicles and 1994-1997 Navistar-equipped International vehicles. Please check the example PCM pictures if you have any questions. Navistar vehicles that can use the Hydra Chip will have the PCM mounted through the firewall. If your Navistar vehicle has the PCM on the side of the engine, you will use our Orion Reflash System.
Features:
- Easy to read two-digit removable display switch for SWITCH-ON-THE-FLY control
- Seventeen positions including built-in Module Bypass [00] and No Start [nS]
- Program and reprogram using our free HydraFlash software
- Supports Hydra Chip™ calibrations for all 7.3L Powerstrokes
- FREE access to Power Hungry’s extensive library of calibrations
- FREE Modified Valve Body versions for many popular calibrations
- Modified Injector tuning for popular calibrations and injectors (additional, one-time charge)
- Fully compatible with PATS-equipped vehicles
- Program your chip in seconds using any or all of the positions
- Create printable calibration list for reference
- Optional USB extension cable for programming in-truck – never pull your chip for programming again!
- Read the factory PCM calibration directly through chip with optional USB extension cable
- Made in America: Wherever possible, every part of the Hydra Chip™ is sourced in the United States. The boards and ribbon cables are made in Florida, the switch case comes from New York, the switch decal is made in Washington, the boxes come from California, and the whole thing is assembled in Georgia. There are individual components that are only available overseas, but we put tremendous effort and pride in finding all the US sources we possibly can. We believe in promoting American jobs for the strength of our country.
The Hydra Chip™ always has [00] bypass mode and [NS] no start built in, with 15 more positions you can program from our database. The choice is always yours.
Please Note: [00] and [NS] are not switch-on-the-fly and do require you to shut the vehicle off and cycle the key to get in and out of.
Also note: These Hydra Chips will not come pre-programmed. The end-user or end-installer will need to select the appropriate tunes. This can be done via our HydraFlash software. Instructions can be found at HydraHelp.com
