KC Stock Plus Billet Turbo - 7.3 POWERSTROKE (E99)
Product Code: 300133
$1,090.00 1,090.00
Recommended Injectors: Stock
Maximum Injectors: 160-Stock
  • KC Billet compressor wheel Update
  • KC Turbos SXE Turbine Wheel Update
  • 360 thrust bearing
  • One year warranty
  • 100% drop in turbo with all parts to install
  • Comes with all gaskets and o-rings to install
  • No Core Charge
It is a stock sized turbo that has been completely gone through and upgraded. This turbo will spool faster, run cooler, and make more power than stock... but this is not a "larger turbo". This is basically a pre-built turbo with our "balanced assembly" that has our warranty on it and is truly drop in ready compared to the DIY Balanced Assembly.
