Alliant Power Fuel Injectors - Ford 6.0L Powerstroke
Brand: Alliant Power
Product Code: AP60900
$1,648.43 1,648.43
-Contact for availability-
Alliant Power 6.0 Powerstroke Injectors – New & Remanufactured
Bring your 6.0L Powerstroke back to life with Alliant Power fuel injectors, available in new or remanufactured options. Designed as direct-fit replacements for 2003–2003 Ford 6.0 Powerstroke diesel engines, these injectors deliver dependable fuel delivery and smooth, consistent engine performance.
Alliant Power injectors are built to OEM specifications and are ideal for replacing worn or failing factory injectors. Whether you’re maintaining a daily driver, work truck, or tow rig, these injectors provide the reliability and fitment Powerstroke owners expect.
Key Features & Benefits
  • Direct-Fit Replacement for 2003–2007 Ford 6.0L Powerstroke engines
  • New or Remanufactured Options to fit different budgets and build goals
  • OEM-Spec Fuel Delivery for smooth idle and balanced engine operation
  • Improved Drivability including better throttle response and consistent power
  • Compatible With Stock Tuning – no modifications required
Ideal For:
  • Stock injector replacement
  • High-mileage engine refreshes
  • Daily drivers and work trucks
  • Towing and light-duty performance use
Why Choose Alliant Power?
Alliant Power is a trusted name in diesel fuel systems, offering injector solutions that match factory fitment and performance. With both new and remanufactured options available, you can choose the right balance of value and longevity for your 6.0 Powerstroke.
