Dipcao DTech Valve Cover Noise Isolator Grommets LB7
Replace your tired old factory valve cover noise isolator gaskets with this set from Dipaco DTech. This kit contains enough grommets to replace one bank.
Noise Isolator Grommet (12 PK)
Model year 2001 - 2004.5
Noise Isolator Grommet DT97225457 is for use in GM 6.6L LB7 Duramax diesel engines. Comes in packs of 12.
