BFT Scorpion 2 Replacement Motor
The updated Scorpion motor specs trump the first-generation pump motor with the following improvements:
- Integrated diode protection built directly into the pump base.
- ~30% increase in RPM, increasing from 70GPH to 97GPH at 70psi
- Maximum 12a draw
- Improved case sealing, resulting in better weather/element protection.
- Seals and armature winding insulation rated to 390*
- All parts interchangeable with previous generation Scorpion line.
*** This motor can be used with any BFT pump head design, and can also mate to any pump head that uses DPP/FASS EM-1001 or EM-1002 motor. Note that with the DPP/FASS pump heads, different length mounting bolts may be required***
Additional Questions may be found in our Scorpion Pump Rebuild Instructions
