Scorpion Pump Rebuild Kit
Our pumps are rebuild-able!
This pump rebuild kit allows you to rebuild any BFT Pump, as well as most FASS/DPP pump designs.
Kit includes:
- New High-temperature Viton pump head shaft seal
- Pump Seal Press-tool (uses any drill press)
- Replacement motor O-Rings
- Replacement Pump cavity O-ring
- Replacement mounting plate O-ring
- Replacement wear plate O-ring
- Replacement wave spring
*** NOTE *** While most of these components can be used to build the DPP/FASS "square-head" pump design, you will have to RE-USE the "ball and spring" FPR and provide new gasket material for these style pumps ***
Additional Questions may be found in our Scorpion Pump Rebuild Instructions
