SSB - Solid State Brain
The SSB allows you to see Temperature status, Pump status, Pressure status, as well as your Engine Run and Solenoid data. In addition, visual cues are given for failed fuses and micro-relays.
The SSB keeps a running (and resettable) time for your filter, pump, number of pressure switch cycles, and your purge solenoid.
(Note: This unit is compatible with original DFA V2 and DFA VegiRam systems. Some additional and simple wire splicing will be necessary.)
The SSB upgrade includes:
SSB
SSB Wiring Harness
SSB Power Harness
OLED display
OLED USB Cable
This kit will use your existing Contura/Carling switches
